I know there are not enough of these requests but perhaps I'll put in a little information in this thread to make it more interesting.
Currently have a JD345 (54 inch deck) that I use to cut almost 2 acres with just a small hill toward the rear of the property so terrain is not really a factor.
Like everyone else, I want to cut quicker and better. Right now it probably takes close to 1.5 hours and quite sure I can cut that down with a faster ZTR mower. I talked the wife into a budget of 5G max with the understanding this might last till I'm 60+ (43 right now). So, having difficulty deciding if I want a very nice residential mower or a cheaper commercial mower. I am not even sure if I should be concerned with buying a commercial mower as I am not mowing 6 days a week with it.
So far, only talked to a Salesman at Weingartz about a couple different models. Seemed to be high on the Exmark Quest S Series. I know I see many crews using that brand around my area. The 60 would be ~4800 out the door. Haven't researched their self-made engines to this point. I know it seemed incredibly easy to change the oil.
While he was looking up the price for a bagger, I found a Cub Cadet ZF L60 which would be about $4100. The reviews seemed pretty damn good.
Then I found the Hustler Raptor SD60 today and that seemed like it would work as well. Looked like there was some suspension mods i can make as well. Yard can get a bit bumpy in areas.
And in addition, been looking now at the Ariens IKON models and the JD535's as well. The Gravely's and Scags....those don't have bad reviews either. So many choices.
That said, I know there are some important factors to look at however. Seems like transmissions are talked about most. Read that some have hanging decks and some have fixed decks. My JD has what I think is a hanging deck? I assume that would keep the ride smoother if that has some room to wiggle around?
Some decks can be detached quicker than others which would be nice. Not exactly easy to get to the blades on my JD
So, guess I'm asking if you had 5G burning a hole in your pocket and needed a new ZTR, what would you buy?
Thanks!
Thanks!
