Briggs and Stratton 33S877-0019-G1 Simpson Intek Series, 19 HP, 540 cc, Single Cylinder Engine
I have replaced the coil twice in the past few days each time i diagnosed a no spark situation and replaced coil. each time it started right up and ran till i killed it and would not restart. I have removed the kill wire during troubleshooting, If I understand it correctly removing the kill wire from the coil bypasses all safeties. The magnet on the fly wheel seems strong and the key is intact. I did notice a very slight wiggle in the magnet when using the tip of a screwdriver to move it but does not appear broken.
Any help would be appreciated.
