Hello. My Mower has been in storage for 6 years. The mower has low hours and looks like brand new, seriously! I followed your previous instructions. I changed the oil, air and fuel filters, put in a new plug, sprayed the cylinder with PB Blaster and let it sit for a week. Today, I cranked the engine with the plug removed to blow out the Blaster and lubricate the cylinder and engine parts. I removed the air filter and poured a little gas in the carb to prime it. Fuel appears to getting to the carb. I pulled the fuel loose at the carb and fuel came out. The engine started but burns the fuel I primed and that's it, add more prime, engine starts and stops. I did this five times with the same results. As soon as the primer fuel is gone, it stops! Any recommendations will be greatly appreciated! Thank you in advance.
Rick in Tennessee
Rick in Tennessee
