1967 John Deere 110
brizjuan
I recently started restoring my 67' 110 with an 8 hp kohler motor... When I took the valves out the parts got all jumbled together and now I can't remember which spring goes with which valve... One of the springs is longer than the other... I'm thinking the shorter one is for the intake valve? Also one of the valves had that little bearing looking retainer to keep it in place.. N e ideas which valve that goes with as well... Thanx
Elias40
Guess since nobody else chimed in, we will stick our neck out.
Is it possible to post pictures, and have all the parts? Maybe we can help.
If you would post the model numbers it would help us know which kohler engine you have.
Ddfd37
Sounds like the k181 motor. Go online at Kohler and view under k181s. And use serial # off motor for the one u need. I will look up web page and try to put link on here. Have same John Deere tractor 110 from 1966.
Ddfd37
Have many JD's
