Hi need help grass is growing fast and tall. Tried to start 1st time yesterday after winter storage (before storing I drained the fuel) and it just cranks and cranks and wont start. I check spark and compression then checked for fuel at filter. It was dry now that's a problem lol. When I prime carb with gas it will run long as i feed it gas, but it will not pull fuel from tank. So here's my question, Does my mower have a Fuel Pump or is it gravity feed? I have looked thru manual but cant find that answer.
My mower is
craftsman
model 917.252561
42" cutting
19hp twin I/C gold Briggs
Any info from you grass cutting gurus would be appreciated thank you
My mower is
craftsman
model 917.252561
42" cutting
