marinegrunt
- Apr 10, 2017
- Threads
- 5
- 21
I have a 16 hp Briggs Vanguard on a Karcher hds 1200 hot water pressure washer. It's electric start but it won't shut off when key is turned off. I haven't had this thing that long so it's still a work in progress. I did take all of the shrouds off and powder coat them I don't see that causing any issues unless something isn't making ground somewhere. It looks like the grounds are all by wires anyways. I did replace a bad diode on the coil ground wires but that didn't do anything.
Where else could the problem lie? Key switch?
Thanks in advance for any help.
