Franken-Roper
- May 20, 2013
- 18
Ok does anyone know where I can get an wiring diagram to look on how to hook up the elctrical wires on my Briggs? I put the motor on the Rally Roper and when removed from the yard machine I removed it all in one peice wires and all still hooked up. The problem is when I hooked a battery to it the motor didntdo jack. But if I touch my boost pack directly to the starter the motor rolls over fine. I just dont have much knowledge on the new electric systems on the motors so any help is appreciated. Here are the numbers.
Briggs & Stratton I/C Quiet
Model: 267707
Type : 1272-E1
Code : 99111ZE
Thanks
Model: 267707
Type : 1272-E1
Code : 99111ZE
Thanks
