#12A-446A711, need help replacing drive belt!!!
rspice
I can't get it on, I've checked the belt part number, it's correct... Plz help
There is no tension pulley
Have you routed the belt the correct way around the idler pulley. If it is gear shift it should get tight when you leave off the clutch pedal. If it a hydro unit it should be tight all the time.
