12.5 Briggs spraying oil and gas from carb
TheRealHenry
Motor ran great, put it away after a cut.
Next time I tried to start it, it fired right up but then immediately died. I took the airbox off and tried again.
Again it fired right up but then started spitting a gas and oil mix out of the airbox and died.
What's going on here? I'm confused how this could occur especially after it ran fine before it was parked.
Mikel1
Check your oil level. Carb flooding into crankcase then spitting the oil & gas mix out crankcase breather.
