Hi all,
Back again in the continuing saga of this old lawnboy. You can see my other posts on this piece, I believe I am the only one with current posts on this model.
Anyway, was having hard re-starts when hot. I replaced the seals. Now my problem is with the governor setting. I set the initial adjustment per the manual, so the window is 3-4 clicks to the right of the center of the fully opened throttle butter fly. That gives ma 2750 or so, turning the adjusting collar a few clicks to the right (cw) increases the rpm, but causes the hook end of the governor spring to come out of "lever F". Then I have no throttle. I sure I haven't bent the spring and the slider is making contact with the choke plate lever.
I do need some advice, again.
Thanks,
Jim
Thanks,
Jim
