Did yo get it running?
Pic 215856 there is some rust on the stem (is that the inlet valve) which you need to remove with some wet and dry paper, by the looks of the valves they needed doing so you haven't wasted your time there...! if the inlet valve is not bent it should be fine with a clean up, didn't see a photo of the push rods so can't give you an answer to that one.
