Results 1 to 3 of 3
  1. #1
    charm's Avatar
    Join Date
    May 2018
    Posts
    11
    Location
    United States
    Mower
    LawnBoy
    Self-propelled 8237 secondary drive wheel won't disengage
    Another problem with my old lawnboy 8237. The second drive wheel, the one on the left side, won't disengage from self=propelled drive. When I pull the handle back to neutral to disengage it, the right wheel disengages as designed, but it's the one that has the mechanical linkage attached to the handle. Then the second wheel, however, which is connected to the other side, only moves a hair which is not far enough for it to disengage. What is supposed to pull that wheel away from the driveshaft?
    Something may be wrong because from drive engage to disengage, the wheel barely moves at all. The cable is attached. Perhaps a spring is missing?
  2.
  3. #2
    Join Date
    Mar 2016
    Posts
    78
    Location
    Florida
    Mower
    lawnboy,honda,stihl
    Re: Self-propelled 8237 secondary drive wheel won't disengage
    First check #10 spring if it is hook up.Than check #8 clutch assembly.I send some pic,s.Dan
    Attached Images Attached Images
  4. #3
    charm's Avatar
    Join Date
    May 2018
    Posts
    11
    Location
    United States
    Mower
    LawnBoy
    Quote Originally Posted by bogdaN View Post
    I'll check it out. Thanks much.
Similar Threads
  1. Toro Lawn Mower Model 20333 drive wheels won't disengage
    By congaman59 in forum Small Engine & Mower Repair
    Last Post: 06-28-2017, 09:38 PM
  2. Replies: 3
    Last Post: 06-24-2012, 04:11 PM
  3. Replies: 2
    Last Post: 03-28-2012, 07:45 PM
  4. Replies: 6
    Last Post: 03-21-2012, 06:30 PM
  5. Craftsman self propelled drive wheel constantly engaged
    By swede in forum Small Engine & Mower Repair
    Last Post: 06-18-2011, 04:01 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
