kurb.conrad@gmail.com
- May 24, 2014
- 2
- 4
Hello
There's oil dripping underneath. I removed the blades and its not the crankshaft bottom oil seal. The Honda service guy says its the oil seal at the top of crankshaft. This will leak from too much pressure caused by putting too much oil in. I could not see or feel any oil in the area
When I looked closer it looked it was dripping from the bottom inside corner of the cylinder head. I noticed from the parts diagram on line that there is a gasket between the cylinder head and the cylinder body . I am guessing that the gasket is leaking, although the engine starts and runs perfectly.
I could not find any info on YouTube and forums on how to replace that gasket for HRB215. Does anybody have any suggestions?? The engine is GXV140.
Thanks
Kurb
Thanks
Kurb
