McTurff
Where would we be if we never tried something that may have worked !Hello C.,
"Nothing ventured nothing gained" is a saying that seems to fit when no one can provide a direct answer. I suspect many people have either lived with the running issue or gave up.
Aftermarket carburetors are a luck of the draw, and many have gotten better over the years, but they are still not a perfect solution as a bolt on and go option.
T
Drilling the extra hole will just line up with the extra bowl vent and that is no harm. It may provide some kind of "atmospheric balance" that only a well-trained carburetor engineer would be able to explain.
I've dealt with many automotive and small engine carburetors over the years, and I know they all require an ideal fuel/air "balance" to function efficiently.
Just wish they made carbs for these engines with the mixture screw?
They do for the single cylinders?
Anyway thank you gor all the input
I picked up a nice opposed engine yesterday and looks like may be a good runner for another project it was in an old mower was going to check out the carb on it but there was a big wasp nest in it!!
Loaded this thing in my truck and unloaded opened hood several times on that mower don't know how they didn't attack me!!
So will look and see what carb it has on It today!
I have time to drill the hole will be after I have exhausted other options!
Thanks Doc
