Intek 24 HP V-Twin will not stay running
Marcellus311
Briggs and Stratton V-Twin engine on Husqy YTH24v48 (2018). Wasn’t starting at all so have replaced: fuel filter, fuel pump, spark plugs, battery, solenoid, air filter, and carb (new). Upon carb replacement, it now starts but will not stay running unless we manually manipulate the automatic choke (see linked video below). Getting too much fuel, not enough fuel? Not sure how to adjust it as there doesn't seem to be a fuel mixture adjustment screw on the carb. Appreciate any ideas. Thanks.
hlw49
You are not getting enough fuel for some reason. Did you check the fuel lines from the fuel tank to the fuel pump? There is no adjust on the carb.
Marcellus311
Thanks for the reply - yes I’ve validated that fuel flows freely through to the carb. It seems like the auto choke air vane is closing after start when it shouldn’t stay open. Not sure if it’s a bad linkage or spring or something, but also not sure that’s it. Thanks for the help.
Post engine model and spec. I like to look the OEM carburetor images. Also the carburetor you installed OEM or aftermarket?
The choke air vane is operating as intended, the suspect is the carburetor itself.
Marcellus311
Thank you: Model # 44N877-0003-G1​
And yes, it’s aftermarket. Looked well machined and seemed to fit perfectly, but is aftermarket, yes.
sgkent
how old is the fuel
Marcellus311
Hm, found this on the floor. Not sure it’s even part of the mower. This look familiar to anyone? 😬
Craftsman Garage
I see a few things. I have been through many Husqvarna with briggs twins like yours, that definitely didn't come from this machine. The aftermarket carbs won't have a fuel mixture screw due to EPA regulations. Did you try cleaning and/or rebuilding the original Nikki carburetor? Nikkis are bad enough, I would guess that aftermarket would be even worse. It looks like the improper spring is on the throttle link to the carburetor. I don't think that would cause this issue but it may be doing something. You replaced the fuel pump? Have you tested that it is pumping good? You installed a 4-bolt aftermarket carb, very common in amazon or eBay carburetor sets, which, in my experience, are terrible. I recently took apart 10 or so new fuel pumps in that style that I had sitting around, and only 1 out of the 10-12 fuel pumps I disassembled were functional inside. I recall that the one-way valves and diaphragms inside were a very cheap poly/rubber like material. I now only buy the briggs OEM pumps for everything. TL:DR, put the briggs fuel pump back on!
Since you have to close the choke for it to not die, this is an issue of not enough fuel. If I were you, I would rebuild the original carburetor with something like this: https://www.amazon.com/APHP-Carbure...x=44n877+carburetor+reubild+ki,aps,290&sr=8-6
I noticed in this kit is an intake gasket which is half blocked, maybe this is a common issue and this is basically a "permanent partial choke" fix for the lean running?
Marcellus311
Just memorializing the solution here since I finally fixed it. +100 to the aftermarket carb comment. I bought another one (yes another aftermarket), and replaced the first one I had put in. Fired right up and stayed running. So the first aftermarket carb I had put on was flawed. Thanks for everyone’s input, it’s great to get it running again!
