I have a plastic gas tank on a Briggs Quantum engine and the ethanol caused large gel like clumps to form in the tank. The internal screen is plugged up. I blew it out with air but that was not good enough. The gas is not flowing as it should. It is a drip. I can still see debris in there. I am soaking it in WD-40 over night but I am not confident it will be good enough. It has helped but I am wondering if anyone knows of a chemical solvent that will safely clean the screen 100% and remove all of the gel like deposits and make the tank useable again.
I have never had luck with carb or brake cleaner on this type of deposit. I find Kroil or WD-40 works better. But in this case it appears it is not good enough. So far.
Thanks.
Thanks.
