Hey New Members
Scrubcadet10
Moderator
Staff member
from one member to another, welcome to Lawn World!
Want to help us help you?
Post your equipment's model numbers in your help thread. Saves us time, and gets you answers quicker.
Don't know where to find your equipment Model & Type numbers?
Here are links as well as pictures to guide you.
Honda Engines model and type locator
Kawasaki Engines model and type locator
Briggs and Stratton Engines model and type locator
Kohler Engines model and spec number locator
Ariens Equipment model locator
Bobcat model and serial locator
Farmer Jean
This is great, very helpful. I inherited a couple of old mowers and am trying to find info on those. One has been patched and painted and there's not much info online about it, I'm pretty sure it's a great dane mower. The other is an AGTrac riding mower that I can find literally NO information online about at all (see avatar). Both need repair but I can't find model numbers and fear they are gone.
If you can find or post info about where to locate them for either brand that would be most helpful. Thanks.
edit: The 'AGTrac' is not a 'Turf Trac' which was made by MTD. AgTrac manufactures full size tractors but at some point made a small riding mower version. The brand name and horsepower is stamped onto the frame below the seat but that's it, no numbers(that I could find).
If there are no model numbers or serial numbers on the units, post the engine numbers. Someone might be able to check which unit they were installed in. That is if no one has swapped engines.
Now why did you go and do this? I miss Rivets smacking down on new members asking for engine numbers LOL. :)
I didn’t expect you guys picking on me??? Now I need your addresses.
