davbell22602
- Nov 27, 2011
- Threads
- 152
- 1,324
Whats preset carb adjustment on this saw that has the compression relief valve?
1 turn out on each
sounds like you have an air leak, which is probably the reason you lost the first piston. you need to check your fuel line and pulser line for leaks, seals.
When you say pulser line is that the same the carb to cylinder boot?
no but thats a good place to check also, the "pulser line is below the boot going from the cylinder to the carb or carb mount.
