BAGGMAN's MOTOR SHOP
- Mar 11, 2013
- 11
I am curiuos as to what chemical or solution everyday techs use to clean carbs? I dont mean the usual on the shelf stuff. I mean tricks of the trade secrets. I have heard of folks using Pinesol, oven cleaner, CLR, kerosene, Tide, and denture cleaner. LMAO! I have used "Desolve it" it works great. For some reason Desolve It Mechanics cleaner is no longer made. It worked better, (prollly to well as it is no longer availble). I use STIHL degreaser alot to clean carbs inside and out. works great! IDK if STIHL change the ingredients of there degreaser but when they went from an orange bottle to a green one seems as if it is dilluted. I have tried the CLR works ok if you dont mind chemical taste,smeel, and burn! oven cleaner and pinesol i'll pass on that too. I use carb cleaner with the red straw to blow through passage of a carb once all rubber is removed. Just curios as what someone else uses. Always looking to learn something new! :laughing: I haven't bought or had opportunity to try sonic parts wash. Do they work? What brand/model would you recommend for a small idepedent shop?
