dnoonkeste
Does anybody have a picture of the linkage of a tecumseh 10 hp carburetor?
Have you checked into the manual I listed in post #4.
I did but didn't have much luck opening it from that link. I'll try again. Thanks
OK I tried downloading it instead. So I will check it out that way. thanks again.
Look carefully at pages 27 and 33. Page 27 shows in figures 7 shows the linkage setup for most TVS models. Remember the adjuster plate is upsidedown. Page 33 figure 26 show the same in a little larger picture. Make sure that the linkage from the governor rod to the carb is in the correct hole on the throttle shaft. Also take a close look at figure 12 on page 29, on how to set the adjuster plate.
