Spindle part#
I was wondering if anyone might have a part# for deck spindles for a Cub cadet HDS 2185 with the 48 LT 301190 deck?
Would you please double check the model numbers you posted. I can't seem to find anything with those numbers.
The Cub model# is 136-288-100, and the deck is the 48Lt 301190. Thankyou in advance for any info Mr. Rivets. I was able to find a 918-04394 spindle part# but I wasnt sure if it was correct?
Here's what I can find from the info you posted, going to the Cub Cadet parts site. Your deck assembly number is 190-301-100. The spindle assembly number is 603-0835.
The MTD spindle number you posted 918-04394, has been superseded to a 918-04426. I don't know how you found that number and it may fit your Cub Cadet, I have no way to do a cross reference that number. Don't know if this helps or confuses things.
It is actually my neighbors mower he sent me the number with his cell phone, and didnt specify if it was the mower#, or the deck#. I think the part# you gave me should be corect. Thankyou for the help Mr. Rivets.:smile:
