Look what I just got
MowerMike
Community Leader
I just picked up this Echo PE-225 stick edger at my local Home Depot store after returning the new Ryobi cordless stick edger that died after 10 minutes of use. Got in some edging before sundown, and the difference in power between the Echo and the Ryobi is tremendous. :biggrin:
Looks awesome! As you know, I got the same one in December...I love it so far! I got some good edging time in the other day (see pictures). Please tell me how you like it once you get to use it some more, and maybe we can help each other if we have a question! :tongue:
Edging around the flowerbed: 1.jpg
Edging along the road: 2.jpg
So today I used it and noticed that the gearbox gets really hot. Is this normal or do I have a problem ?
They do get warm, You may want to check and see if the head has enough grease.
The manual says to use either "POWER BLENDX" or "lithium base" grease. Would white lithium grease work, or is it something different ? TIA
I don't own an edger. Always use a straight shovel and a shingle removal shovel. How well do they work? Serious time savings?
YES! It saves tons of time and looks just as good/better. See my pictures in post #2 of this thread. And where I live the grass is not higher than the road/sidewalks (like MowerMike's pictures), so if it was it would look even better! :rolleyes:
It's like the difference between using a manual reel push mower and a powered rotary mower.
I have not noticed if that happens on my edger, but I know it does on my trimmer and nothing has happened because of it!
That's good to know. The edger uses the same type of shaft and gearbox as your trimmers. Do you notice any difference between the curved shaft GT and straight shaft SRM ?
