95 snapper rer won't sift
sandoya
hi, I have a "95 28 in. rer. Ihad to replace the brake /clutch cables because they broke. I can't get it to shift. It will shift in the upright positiion, but when i put it down on the ground, it won't shift. I can't figure out why. Any ideas? Other than burning some oil, this has been a great mower for 18 years. I don't know if it's worn out or not. I thought I'd join up and ask. thanks in advance.
Joe
Carscw
Try not pushing the Pedal all the way down just push it about 3/4 the way
Sent from my iPhone using LMF
sandoya
Hi, thanks for responding. I tried your suggestion tonight and no go. I'll keep working on it this weekend.
Joe
sandoya
Re: 95 snapper rer won't shift
I figured out why my snapper won't shift. the axle bearing or whatever the axle goes through is so worn out that when I put in on the ground the axle rises up enough to stop the rubber wheel mechanism form moving onto the drive plate ( not sure of the terminology) . I'm going to try and rebuild the axle/wheel assembly. It looks like a straight forward job, if I can get that triangle shaped piece off. Do I just have to drive off? I tried and couldn't get it to move at all. Any input from anyone will be appreciated. This may lead to a total overhaul, would be fun.
valveguy
In 1764 Ben Franklin said, " Snapper RERs never wear out."
SeniorCitizen
Sometimes their design ignorance causes them to simply fall apart and it costs about 200 bucks to get it repaired.
valveguy
Parts do wear out but routine maintenance is required on anything mechanical; trimmers, edgers,saws,refrigerators, washing machines, etc. At those times you have to spend some bucks. A little preventive maintenance can go a long way towards reducing those expensives and I have always surprised myself after attemping to do most repairs myself. Right now the only problem I am having with my 33" RER is finding the proper length of belt to fit it. I have purchased two belts, with the correct part no. and both are too short and keep the blade engaged, even without touching the tensioner lever. My neighbors are cutting their lawns already and mine is beginning to look a little shabby.
SeniorCitizen
Are you following the manual instructions for belt replacement?
Carscw
Belt length should be 71 1/4 inch.
valveguy
I bought an Oregon 72" belt and it is too short. Someone else on this forum said it takes a 74" belt and I am having difficulty finding that length. I hate to give in to buying from the local dealer because they are very proud of their merchandise. With the 72" belt the blade is engaged all the time. I ran it for about 20 minutes in hopes of it stretching but that didn't happen.
