cub cadet dz50
ronnie bowman
i have a cub cadet dzt50 zero turn,and i removed the kawasocki 20 hp motor and i put a 20 hp briggs motor on it.now the batt.want stay chaged.could someone help me with this.i wired the mower and i used the volt reg. off the kal. and put it on the briggs.
chance123
The voltage regulators on the Kawasaki and the Briggs are different and not compatible. Briggs uses several different amperage output alternaters. I would go with a Briggs regulator that matches the Briggs engine/alternator.
ronnie bowman
ok,how do i go about doing that?
ronnie bowman
does anyone know how to wire a briggs 20 h,p,to a cub cadet zturn,i have it running but i cant get it to charge
Post the model numbers for both the tractor and the engine. I will see if I can find wiring diagrams to help.
