scott47429
- May 29, 2012
- 646
that may be a good product im not sure i havent seen one in real life but as i said before and as alot of other people ar saying also that a zero turn is going to make the biggest diffrence of all i say if your in the market for a new mower then try one out and see if it works out for you if you buy from a dealer and thats what everyone would recommend most of them will let you test drive one so you can see if its what you want or need good luck with you venture
