lawn mower fanatic
I like the nice and big tires on the rake! :thumbsup:Here is the rake at work. It rakes straw pretty clean if the ground is relatively smooth.
A neighbor that works on mowers gave me that set of tires. They came off of the back of a John Deere mower or some kind that he junked out. The smaller ones that are on my baler were on the front of a Craftsman mower also.
so glad I found your post about the rake. it is the first and only one I have found that might help me out.
I've an acre and a half of low land I keep mowed regularly, marsh grass actually. looks good when cleaned up. but this time of year it is still too damp down there to work easily. after 2 cuttings I need to rake up or lawn vac the area, the clippings get too thick to mow again. I use the wheel rake, aka estate rake, ( the vee shaped one) which windrows the clippings very nicely, when it is too thick I need to remove a center wheel to allow the windrow to pass through rather than plugging the rake.
my big problem is that I need to gather the windrows into small piles with a hand rake , then drive around with a trailer and fork the piles onto the trailer to haul away. I am quite tired of handraking 1+ acre into 70 piles to fork up.
I have no 3 point hookup so have been searching for a trailer rake that will gather up the windrows into piles and work similar to an old fashioned dump rake.
yours seems to fit the bill quite nicely. I usually gather up about a 20 foot length of windrow from both directions into a pile.
later in the year when it is much drier down there I can simply mow one day, and the following day do it again with the lawn vac and dump all of it at a convenient place. ( the lawn vac doesn't pick up windrows too well, it dozes the clippings ahead of the mower deck. works just fine on the broadcast clippings)
then I use the pine straw baler that I built and bale up the clippings into tidy bales, easy to handle then.
my next question for you is, does your rake have teeth on the lower edge? how long, how many, what spacing? does the unit need to be locked up vertical to prevent it from dumping when you don't intend to just yet?
Denny
DRH
Denny
DRH
Sorry I just saw your post. I don't come here as Soren as I once did. I finally had to mount the rake on the front of the tractor to get it to work good.HAS THIS RAKE HELD UP. ANY WAY TO GET MORE PICS OF HOW YOU BUILT IT, TINE SET UP, AXEL SET UP ETC... WOULD LIKE TO BUILD ONE MY SELF. THANKS, JR
