Does anyone have a Sears LT8/36 or LT10/36 that they are restoring?
EZRYDER
  • / Does anyone have a Sears LT8/36 or LT10/36 that they are restoring?
I have some nice body and chassis parts and other misc that are left over from my restoration if anyone is interested.
Larry
Briana
Welcome to LawnMowerForum!
I moved your thread to the Private Party Ads forum. :smile:
silver1
I have a LT 10 36. I need the throttle cable and the wiring harness.
I may also need the mower deck mandrels. I'm still trying to get it
running correctly as the carb. linkage was missing parts. I have them
now. LB
EZRYDER
now. LB
I used a generic throttle from the local equipment dealer for $15 and it worked fine on my LT8.
Harness on the 10 I am not quite ready to give up yet. Going to try to start the motor on th LT10 one more time before I dismantle the whole thing. What is a deck mandrel? I have a deck on the 10 but never used one and will be selling deck parts because I believe it is incomplete.
Larry
silver1
It is the jack shafts. The deck has two. The belt on top, the blade on the bottom.
Don't need the harness. I got 1 from ebay. I need the steering sector gear and one
front light for my LT 11 36.
LB
EZRYDER
LB
OK, I will digest what you said about jack shafts because I don't know what they are either. I used the steering gear from the 10 for my LT 8 which had broken teeth. By light, do you mean bulbs or is there an enclosure? My 8 and 10 both have the light bulbs directly attached to the hood and they can be bought at an auto parts store.
