Emarshbuck
When trying to prime this engine with the primer bulb, the bulb blows air into the gas tank rather than bringing gas up into the carb. When I remove the gas line from the carb and press the primer bulb, the air blows out of the carb with a high pitch whistling sound.
I suspect the carb needs a kit.
Suggestions?
Suggestions?
