jekjr
- Jan 3, 2013
- Threads
- 271
- 1,969
Don't know how many of you run zero turns but here is one that you need to watch out for.
Many times with a zero turn you can run right up beside a power pole with your rear tire and go around the pole very close virtually eliminating having to come back and trim.
Often times a power pole will have a nail in it. Even if it is bent in so that you can't see it with a close examination it can very easily snag the sidewall of a tire.
Right after I got my Kubota I found a place where something had snagged mine and could not figure out what did it. I have since then found a second one in the same tire. (Left Rear) I noticed a pole the other day that had a nail in it that was bent almost flat against the pole that appears to be the culprit.
