Ok its not so much an end play measurement, its just a static level/gap mesurement. But this Kohler tool is crazy.... Can't see why I can't use a simple steel rule (or a thick sheet of glass) across the case?
All the best.
Neo
All the best.
Neo
Also I believe that instruction 3 you cited has a typo...SB "move toward the crankCASE," not crankshaft. are you having fun yet?? :mur:
That's just what I needed to know... Thanks Rivets :thumbsup:...... Never really worry about it when I do a Kohler rebuild.
It's a great feeling :wink:Good escape from the matrix with no solution
