I just got a new Bradley Lawn Mower Blade Sharpener. It appears that this is going to be a great little machine.
I am in hopes that you will use this machine awhile and then post a fine review. Not only am I very curious about these machines maybe it will shed some light into the murky replies I get from my dealer and perhaps others on this site. My dealer has one and will sharpen only those blades that are pretty straight and simple. For example he will sharpen most blades on lawntractors and ZTRs but not most push mower blades. He claims that his machine will not do those blades like mulching blades for example. I have always wondered if he is just to lazy to reset his machine, does not want to bother, has a problem with liability, or if a person needs a different machine for different blades.
The Bradley Blade Grinder is listed on e-bay at buy now for $175. You might bargain with them and get one cheaper than that. Shipping was $30. It came in very securely packed in a box that was then packed inside of another box with much cardboard around it for protection.
If I had to class it I would say it is much better than just a regular bench grinder.
Mine has what looks like an 8" wheel on it.
On the straight blades offf of my Kubota Zero Turn I believe it will do a great job and don't see why it won't have a long life. Grinding a blade does not seem to have hardly any drag on the motor. I ground both ends on three blades and they are pretty thick blades.jekr , indeed a good price and tempting if it works will., good luck with it
