bruceha2000
Like I mentioned, the engine does crank before the battery is charged up - it just cranks rather slowly. It's my contention though that 12.56 volts ought to be enough to start the tractor. .
12.56V isn't fully charged. Seems odd for a 12V battery, no? My 1995 MTD Yardman didn't start today, it was about 25F so not all that cold. Started last week at about the same temps. After I tried to start it to the point the starter wasn't spinning the engine fast enough to start, I took the battery out. It read 12.5V on my meter. I put it on my charger and it said 85% charge. Fully charged it now reads 13.7V. It is labeled as 350A, 275 CCA Walmart - Ever Start.
It is a sealed type so there is no water level to check. This is a used machine given to me by a friend last spring and the date "punches" on the battery weren't done so I don't know how old it is. I'm sure there are plenty of places in the electrical system and engine that could use looking at. Of course this sort of thing always happens when you freeze your fingers off doing them!
