Snow blade white outdoor mower
dawggymike
need to put a plow on . its a white outdoor mower . super 50. do i need an adapter? the deck height adjustment is above the rear wheel , will that effect raising the plow ?
Buckshot 1
:smile: If you could give us more info. Like LT's model number. Is white the color or the make of tractor?
It's the brand of the mower. They look something like this.
And, yes, we would need the model number please. :smile:
Buckshot 1
:smile:Where did you get that MN:? White MTD should start with a 13xxxxxxxxx MN:. Is that tractor an LT or a GT. Is there a LTxxxx or a GTxx on the hood?
here is the number 13ap60tpo904452720
the model number is 13AP60TP090 LT-5000 2008 model. If it has the quick attach deck bracket on the front then you don't need the adapter plates. I believe all models after 2006 were factory setup for the quick attach front mounted attachments. the snow plow will have its own lift lever for the plow. Sticks up on the left side of the mower that you push down to lift the plow, and pull up to lower the plow. It works by a cam over type locking system.
dawggymike
on the bottom of the seat 13AP60TPO904452720
dawggymike
thank you for your help !
As far as I know, MTD is only making one snow plow, that fits all models. The 600,700, and 800 models starting with 13 or 14
