Ric
- May 7, 2010
- 5,765
I just bought a set of blades for my Cub Cadet Z-Force 44" and have run into problems removing the old blades. The three blades are each bolted on by a 1-1/8 nut. I have attempted to remove them with an impact wrench, socket and pry par, socket - pry bar - sludge hammer combo, torch, solvents, and praying. I cannot get a single nut to rotate and looking at the threads as well as the manual, they are common threaded nuts which left turning "should" loosen. Any suggestions? It's hard to even get a bite to wedge the blades stationery on this thing.
THANKS!
I know where you are coming from, the problem is the nuts on the Z Force is that they are torqued at something like 110 to 120 lbs. I had a time with getting them off mine the first time. If it's the lap bar model you will also need a wrench to fit the middle spindle on top to hold that nut, if you don't you'll turn the spindle out from the bottom. Where in Florida are you located. They do turn to the left to remove the nuts and it will take a fairly good impact to remove them. You may want to consider taking the mower to the shop and let them remove the blades the first time or this time if someone got carried away installing them, just don't let them install them. When you get the blades off and you're ready to re-install them torque them at 80 to 90 lbs that's all you need.
