The deck is off and upside down. I did only heat the nut whereas the purpose of heating is for expansion and you want the nut to expand off the bolt threads....thus only what the bolt is going through is ever heated when using a torch. Penetrating oil has soaked all day, they are right hand nuts, and I don't want to have to replace the expensive assemblies because old blades are stuck to mine. I would consider replacing the shafts if I could get those off. A cold chisel would have about the same effect as the impact I am using as well as the rotary hammer I put on it. I have a garage full of tools and nothing is working. I just can't believe all three nuts won't turn. I talked to my buddy who owns a lawn service and uses cubs and he had no advice other than what I've tried. I may find a way to strap the deck down and attach an aerial winch to the breaker bar to see if 10,000 pounds of force will do anything (That's what we hoist the alligators up with)
There is one more catch....blocking the blades with a 2x4 does no good whereas the center hole of the blades are round (not star). Therefore they just spin when torque is applied to the nut. It's rather difficult to get a wrench on one side and put everything I have into trying to get the other side off.
