New old mower
Jamath3
Just picked up 1965 braodmoor 707. First step is to get it running then if I have time fix it up.
I will do both with it. I took the carb off and cleaned it, replaced coil and now have spark. Tonight I will put back together and see if it runs.
Let us know! put a video on if you can! at least see if the engine runs and drives. then try the mower deck. dont want to burn anything out right after you got it!!
Everything works great on it. It was not a bad find for $41. The belts are old and jump off sometimes but was able to give it a good test. I will post a video when I replace the belts. My daughter went with me to pick it up and now is claiming it as hers so I get another person to help cut the lawn.
