I have a Husqvarna YTH21K46 mower with a Kohler Engine (SV610-0212). I'm attempting to troubleshoot problem starting the mower which is becoming very time consuming and expensive. In short, I have replaced the battery, solenoid switch and starter motor. However, none of these have resolved my problem.
The mower will not turn over at all. They solenoid switch sounds as though it is engaging (repeated clicks when I turn the key) however, when I measure the voltage from the solenoid switch to the starter, I only get between 6 and 7 volts. However, I am getting between 12.4 and 12.8 volts from the battery to the solenoid. I see one fuse that is intact, but there could be others that I don't know about.
What could be causing the voltage drop from the solenoid to the starter?
Thanks in advance.
Thanks in advance.
