Sears Craftsman Mover
DWSorboen
I have a mower that cuts the engine off when I release the brake/clutch or try to engage the blades.
Can't seem to locate the owners manual. Hoping someone has some ideas. Thanks.
sears has a secondary contact switch built into the wiring harness, which acts as a jumper when it is unplugged from the switch to activate the kill system to prevent people from just unplugging the switch.
the same thing just happened to my yard machines. its a kill wire. it grounds out when there is movement. disconnect that wire and you should be fine. if you want to shut it off then connect those wires back.
