Repairs Oil change notification
what?
I have a 2006 1046 (v twin) purchased recently
I got an oil change notification on the display. I'm ok to change oil, filter etc. How do I remove the displayed oil change notification?
Many thanks
You have it ... no reset, this is the most crude & not helpful "reminder" you could have...
A simple notation change oil every 50 hours, could have accomplished the same thing... but instead, I use what I consider an easier method... I use a good synthetic oil and change once a year, I aim for April... Works great and I reset whenever I get a new calendar... :smile:KennyV
Many thanks
Actually you can not remove the notification, it will do it on it's own. It may go out when you start the engine and probably come back on in a few minutes (mine did) but after a certain time, I think mine was something like two hours of actual run time it will shut off until the next reminder to change the oil.
