slammed
They sell the kit at Home Depot or napa or advance auto part for more then half price of a dealer
Sent from my iPhone using LMF
I have not seen a kit. Can you post a pic of it for us to see?
I have an Echo PB-500T backpack leaf blower. It will start right up and run fine for about 20 seconds then start to die out. I can keep it running but it will not rev high at all. If i pull in the trigger all the way it will sputter out. And if I try to slowly hit the trigger it will rev up a little then start to die out. Any idea what this is?
I think it was bought sometime around the beginning of 2011. I have no idea how many hours it has. We use it for spring/Fall cleanups and just to blow clippings off of driveways in the summer.
Ok, Try checking the spark arresting screen on the muffler first before you spend money on filters and lines, it not going to cost you anything. Use the process of elimination, cheapest things first. Your arrestor could be a flat screen on the side of the muffler or a round tubular screen through the side that you can just pull with a pair of pliers. Clean it with a wire brush and a air compressor if available. A plugged spark arresting screen will make the machine do exactly what you're describing.
Yea I saw some at Lowe's today. Thank you though. The hoses just seem smaller then what is in most equipment I have.
