I'd reconsider LEDs... Any snow application using LEDs will require you to constantly clean the lights... They don't generate enough heat to melt away the snow covering them... I won't use them on my salt spreaders.Snow builds right up over them.
			Hmmmm..... thanks for the warning. I was leaning toward LEDs for two reasons: 1. Bright light and 2. Low amp draw for the amount of light I get. I'm hoping, if I mount them a distance away from the blower, there will be less snow blowing on them. And, I should be able to reach them from my seat to wipe them off if needed.
I suggest you first get the ROPS and then put the lights near the top of it. That will provide plenty of elevation to prevent the blower and blowing snow from blocking the lighted area.
I am assuming the ROPS would work on his mower. Would you have to get a bigger "roll cage" like in this picture?
(http://www.itradedforit.com/pictures/listings/224_35.jpg)
I can't find a Ventrac 3000 with a normal ROPS bar like on the bigger Ventracs or ZTRs
