Pete.S
- Jul 20, 2011
- 40
My drive belt is slipping and I have a new belt. I can jack up the mower, remove the mower deck and then when I try to take the PTO clutch off the engine shaft I have to figure a way to keep the engine from turning over or holding the shaft still. The upper half of the PTO clutch is held in place by a bracket welded to the bottom of the frame. The bracket apparently keeps the top half from spinning when the clutch is engaged and does not look like it is supposed to be moved or removed. Any ideas or experience with this?
Pete
Pete
