Under $3000 Zero Turn Mower Help
Thanks everyone. Now I'm intrigued by the Zee 2 and I'll have to look closer into the other models mentioned.
Sorry, I know nothing about this stuff. What is the EZT drive that I should be concerned about? That would not be an issue with the Zee 2? Bottom line, I would pay a little more if I could save from future issues but I have to draw the line somewhere!
slightly better transaxle....
It is slightly better....
Depending on how it is used... any system will eventually have problems.... :smile:KennyV
The EZT is hydro drive is hydro drives low end drive unit and is a sealed unit that is a residential unit the Zee 2 has the Hydro Drive 2800 that some manufacturers do use on some of the commercial units. For what you're doing it should never be a concern and could save from future issues. I have the 2800 drives in my CC commercial Z Force and have 600hrs on them in like 18 months and have never had an issue.
The Zee 2 also runs the Kawsaki engine which IMO is a far better motor than that Intek ever thought of being, but that's my opinion. Like I said the Zee 2 would be my choice.
