I take it you experienced something bad happening under these circumstances...?
Every time I reach down into the chute to dislodge wet grass I note how the designer has stopped your reach at armpit so you cannot put your hand into the (somehow) running blade. If it can happen ( somehow), it will.I was thinking about trying to cut out a section, say about 5.5 by 8.5 in the first chute on the top - big enough to get my hand in there and pull out a grass clog. Put a stainless steel piano hinge on it and some lock down piece. My old tractor was a snap to remove the chute and reach in to clear a clog. The PGT9000 bagger chutes are a royal pain in the rear end to take a part to clear a clog. (...and of course, all clogs are cleared with the motor off.)
Have any of you guys ever thought of making an easy access door to clear clogs? Ideas?
RickO
Oil Temp. No, I haven't.
Different question to you guys.
To remove the deck, one of the steps is to pull the bowtie cotter pin connecting the deck sway rod. Why? I did not do this step as I didn't see any physical connection to the deck. Frankly, I don't get it.
What am I missing here?
RickO
and the power to the blades (not the engine power) but the pto power seemed to, well, give up. Not sure how to describe it because it wasn't slipping, it wasn't over-loaded.
RickO
