natenkiki2004
- Apr 22, 2011
- 177
Figured I would post this in case anyone else had a similar issue. The fix for me was about $8 in hardware.
I was trying to disconnect a battery from a riding mower recently and the screw had become so rusted/corroded onto the lead terminal that when I tried to loosen it up, the terminal (poor design in my opinion) just ripped right off. Come to find out later, the battery was perfectly healthy and holds a decent charge, 12.57v over 2 days. So, instead of dropping anywhere from $70-$120 on a new battery, I got to looking online and found the answer; hanger bolts. I got more info and headed down to the hardware store, got some 1/4" hanger bolts, brass nuts and copper washers. Got home, cut the terminal off flat and realized there was about 3/4" solid lead left to drill into. I went in about 1/2" with a 3/16" drill bit and cut the hanger bolts accordingly. Smeared some di-electric grease on the bolt and threaded it in. To top it off, I mixed up some JB Weld and covered the top so the bolt wouldn't untwist and corrosion wouldn't form around the fresh lead. I now have nice new wingnut terminals that are corrosion-free and I can start chasing other electrical gremlins.
Here's a poor picture of the finished product, if anyone is interested I can get a better picture:
Here's where I got the idea from:
http://www.wind-sun.com/ForumVB/showthread.php?15933-Broken-battery-terminal&p=118966#post118966
http://www.wind-sun.com/ForumVB/showthread.php?15933-Broken-battery-terminal&p=120136#post120136
