Repairs Idle Restrictor Screw Discussion for Screw-Restrictor, Idle -
joe smoe
Howdy
Idle Restrictor Screw what is tha scoop? Adjustments if any ect, besides get'n a new Ole Lady Cl;-(P)
Thanks
Joe
Howdy
Thanks
Joe
Those mixture screw restrictors limit the amount of turning the operator can adjust. In other words they shouldn't be so far out of adjustment that it won't run, but that's the theory. Most of the time I pull the plastic caps off so I can adjust them properly after cleaning the carb well. Personally I HATE em but put them back on the weed eater or what-have-you if it belongs to a customer. More often than not I file down the limiter tang and then can turn it anyway I want and still have it on there!
