DISREGARD - PREV OWNER FOUND THE MANUAL. THE MOWER IS MODEL 14SE.
Hi,
I have a 21" self-propelled JD lawn mower. Recently, the mower engine started surging pretty badly, then shut off. Now, the mower starts fine but shuts down after about 10-15 seconds of running.
It was just gone over and had an oil change at the beginning of this season. Filters are good, everything checked out OK.
I suspect that the part is what I *think* is a voltage regulator that is attached to the engine. It is a square device, about the size of a postage stamp, with an integrated mounting bracket (one small nut holds it on a stud) and a single 3/16 in. spade terminal. The back is black epoxy potting, and the part as "TI-36 JAPAN" inscribed on the front.
My issue is identifying this part so I can order one. My mower has a plate on it that provides what I assume to be a model number, which is JD902. Several John Deere parts sites, most of which refer / link to what I think is JD's own parts database, cannot find this mower. I believe it was purchased at a big box home improvement store but what I DO know is that it was NOT purchased at a JD retail store.
Any ideas as to A) what my mower is and B) what this part is?
Thanks in advance from the new guy.
BG
Hi,
BG
