First time poster. Been using push Craftsman rotary mowers (two) for years. Our lawns are flat on a small lot of 5000 sq. feet including the house. Getting on in years so when our current Craftsman push rotary blade retainer stripped, have decided to get a self propelled rotary now.
The grass is zoysia and can be pretty tough to cut. I'm not a religious mower so the grass can get a bit tall (1.5 inches higher than normal) at times with some spots with different grass a bit higher.
When I mow the lawn, sometimes in spots I have to tilt the mower, push it over the tall grass and then slowly lower the mower to prevent binding up the blade and stopping the engine. Also since our front and back yards are relatively small, I need good EASY 180 degree turn ability.
Could you tell me if my current ideas for buying a mower are OK or bad? My ideas are:
1. I'm thinking that I need to get front wheel drive to be able to tilt the mower up, push forward over tall spots, and slowly lower the mower to cut the tall grass gradually. This would only be is some spots, not the whole yard. Since our front and back yards are flat, I don't need rear wheel drive. Would front wheel drive be best for this type of cutting situation?
2. When I handled two self propelled mowers in Sears, I noticed that the one with large rear wheels was harder to push the handle down due to the weight of the mower. It seems that with the larger rear wheels, the wheel pivot points are further back which increases the leverage of the weight of the mower making the mower appear to be heaver. So I'm thinking that when I make 180 degree turns, small rear wheels will be less work due to less weight when tilting the mower to make the turns. Are these correct assumptions?
3. I bought a Craftsmans 370660 front wheel drive mower with small rear wheels yesterday. I haven't unboxed it yet. When I did some research this morning, I saw that this model has plastic ring gears on the front wheels and small metal gears to drive the front wheels. Should I just return this mower or can this configuration last if I grease the gears well?
4. Which mowers have good variable speed mechanisms? The Craftsman 370660 appears to have a drive belt to a small pulley that's mounted on the vertical to horizontal gear box. Sears advertises this model as having variable speed but it seems it is misleading since variable speed appears to be just loosening the belt to let it slip. Seems like a trick advertising. How do other mowers achieve variable speed?
5. Which mower would you recommend for my situation? Would this Honda HRR216VKA at Home Depot be better even though it has rear wheel drive?
21 in. Steel Deck Smart Drive Variable Speed Self-Propelled Gas Mower-HRR216VKA at The Home Depot
Thanks,
Yardguy
