Hi everyone..i have a Craftsman LT1000 Lawn Tractor (Model #917.272670) w/17.5 briggs & stratton IC OHV & i just went out to mow the grass & when i fired up my rider it started a little ruff & after i put it in gear it sputtered really bad & almost died & then it picked back up spewing out a ton of white smoke & got back up to high idle speed then about 30 seconds later it did it again then got back up high idle speed & kept doin it over & over until i turned it off...i checked the air filter (which was filthy) & cleaned it & checked the oil (it was a little low but not that low) & tried again & it did the same thing. any help would be greatly appreciated
