reynoldston
- May 23, 2011
- 5,705
You got so many things going here that its hard to keep up. OK now lets start with the yellow wire. The yellow wire is negative power, no 12volt positive power to the yellow wire at all. Places it picks this negative power from is from the #4 pin through the ignition switch from the black wire #1 and also through the seat switch through the switch from the mower chassis. The mower chassis is negative power from the battery. Also this wire gos through the PTO and clutch safety switch. Now also you have a orange wire going through the PTO and clutch safety switches which is 12 volt positive which starts from pin #5 and goes to the starter solenoid. Now for the confusing part. The PTO and clutch have two positions on them that are on and off with 4 poles which work just the opposite from each other.
